Become a registered member for a cleaner interface and faster page loading! It's free!
hyundai genesis sedan   hyundai genesis sedan
DIRECT LINKS: Genesis Motors | Genesis G70 | Genesis G80 | Genesis G90 | Genesis Sedan | Genesis Coupe | Equus
Go Back   Genesis Motors Forum > Hyundai Genesis Sedan Forums - 3.8 V6, 4.6 V8, 5.0 R-Spec V8 > General 2009-2014 Hyundai Genesis Sedan Discussion
Hyundai Genesis Forum / Magazine Advertise Help us help you! Calendar Today's Posts
Notices
General 2009-2014 Hyundai Genesis Sedan Discussion Forum for discussions regarding the Hyundai Genesis Sedan that don't fit specifically anywhere else.
Hyundai Genesis Forum: Oil Filter on 2012
Reply
Thread Tools
  #1
Old 09-04-2011, 09:59 AM
crusso crusso is offline
Drives a Genesis 3.8 V6 Sedan
View crusso's Photo Album
crusso is on a distinguished road
Default Oil Filter on 2012
Members don't see this ad
I am due for my first oil change on my 2012 and I stopped into my local shop the other day thinking I could get out of there pretty quick but the tech said it looked like he had to take off the skip plate in order to access the oil filter. He said the car has a full skid plate underneath and Hyundai put a hole to access the drain plug but no area to access the filter. This doesn't sound right to me and I haven't gotten my butt under there to investigate. Anyone know if you have to drop the skid plate to change the oil filter?
  #2
Old 09-04-2011, 10:29 AM
Mark_888 Mark_888 is online now
Drives a 1G Genesis 3.8 V6 Sedan
View Mark_888's Photo Album
Mark_888 will become famous soon enough
Default Re: Oil Filter on 2012
There have been some other threads on the 2012 V6 oil changes, and what your service guy said about the skid plate is apparently so. Previous to 2012 the Genesis Sedan V6 filter was on top of the engine bay and very easy to remove, but I beleive they had problems with oil draing out of the filter when the engine was off (and therefore empty when engine first started). Maybe needed some more room on top for the GDI stuff as well.
  #3
Old 09-04-2011, 12:17 PM
Skywagon's Avatar
Skywagon Skywagon is offline
Drives a Genesis 5.0 V8 R-Spec Sedan
View Skywagon's Photo Album
Skywagon is on a distinguished road
Had the oil changed in my R-Spec the other day. Yes, the skid plates have to come off. Perhaps just the front one but I watched the tech take off both front, and a smaller rear, to get to the oil filter.
  #4
Old 09-04-2011, 12:23 PM
Quote:
OP was talking about Genesis V6, which is different engine than R-Spec or 4.6.
  #5
Old 09-04-2011, 02:02 PM
TJPark01's Avatar
TJPark01 TJPark01 is offline
Drives a 4.6 V8 Tau Sedan
View TJPark01's Photo Album
TJPark01 is on a distinguished road
yes you have to remove the plastic panel to access the filter in the new 3.8 GDI in the 2012 V6, takes about 30 seconds.
1. Park the car on level ground.
Start the engine and let it warm up.
2. Turn the engine off and open the hood.
Remove the engine cover.
3. Wait for 5 minutes after loosening the oil filter cap to drain well the oil in the oil filter.
4. Drain engine oil.
(1)Remove the oil filler cap.
(2)After lifting the car, remove the oil drain plug and drain oil into a container.
5. Replace the oil filter.
(1)Disconnect the oil filter cap from the oil filter body.
(2)Remove the oil filter element.
(3)Check and clean the oil filter installation surface.
(4)Check the part number of a new oil filter is same as old one.
(5)Install a new oil filter element (A) and new O-ring (B).
(6)Apply clean engine oil to the new O-rings.
Lightly screw the oil filter cap into place, and tighten it until the O-ring contacts the seat.
(7)Finally tighten it again by specified tightening torque.
Tightening torque :
34.3N.m (3.5kgf.m, 25.3lb-ft)
6. Fill new engine oil.
(1)Install the oil drain plug with a new gasket.
Tightening torque :
34.3 ~ 44.1N.m (3.5 ~ 4.5kgf.m, 25.3 ~ 32.5lb-ft)
(2)Fill with new engine oil, after removing the engine oil level gauge.
Capacity :
Total : 6.0 L (6.34 US qt, 5.28 lmp qt, 1.58 US.gal)
Oil pan : 5.5 L (5.81 US qt, 4.84 lmp qt, 1.45 US.gal)
Drain and refill including oil filter :
5.2 L (5.49 US qt, 4.58 lmp qt, 1.37 US.gal)
•Fill a half oil of the total amount first and do the rest again after about one minute later.
•Do not fill oil over the 'F' line, checking the level with the oil level gauge.
(3)Install the oil filler cap and oil level gauge.
7. Start the engine and check to be sure no oil is leaking from the drain plug or oil filter.
8. Recheck the engine oil level.
Click image for larger version
__________________
4.6 Platinum Metallic/Black
  #6
Old 01-11-2012, 12:14 AM
decan9 decan9 is offline
View decan9's Photo Album
decan9 is on a distinguished road
well...I parked too close to a concrete wheel stop.....when I backed up, it tore up the plastic thing that hangs down behind the bumper...pushed it back up...but where do I get a new one, and what is it called?
  #7
Old 01-11-2012, 12:39 AM
homeofstone homeofstone is online now
Drives a Genesis 4.6 V8 Tau Sedan
View homeofstone's Photo Album
homeofstone is on a distinguished road
Quote:
Dealer parts department. Its an OEM part. Also most high end cars today have a cover over the bottom of the engine compartment. My Acura did, as does my 2005 Mercedes.
__________________
Current vehicles:
2011 4.6 with tech, Athens, GA owner
2011 Mercedes E63 AMG
2005 Mercedes E500 w/sport pkg.
2013 GMC Yukon XL Denali AWD
1965 Ford Mustang 289cid V8 restored
  #8
Old 01-12-2012, 05:55 PM
fresh-popcorn fresh-popcorn is offline
View fresh-popcorn's Photo Album
fresh-popcorn is on a distinguished road
I did my first oil change last weekend on my R-Spec and thought about cutting out a square right under the oil filter and placing a hinge there so I did not have to undo the covers.
Would make changing the oil/filter much easier/faster
  #9
Old 01-17-2012, 06:54 PM
genesis20 genesis20 is offline
View genesis20's Photo Album
genesis20 is on a distinguished road
that is exactly what I am going to do the next time oil is changed. Don't understand why there is access to the drain plug and not the filter. Makes no sense.
Reply
Bookmarks
Download the Cars Connected app
Tags
2012, filter, oil
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Hyundai Genesis Ads
Remove this column
My Pledge
Buy OEM Genesis badges and emblems
cars connected social network cars connected social networking app for ios cars connected social networking app for android
Powered by vBulletin® Version 3.8.9
Copyright ©2000 - 2016, vBulletin Solutions, Inc.
GenesisOwners.com recognizes that "Hyundai", "Genesis" and "Genesis Motors", it's logos and various model names and numbers are registered trademarks of the Hyundai Motors Corporation. These terms are used for identification purposes only. GenesisOwners.com is not affiliated in any way with the Hyundai Motors Corporation, Hyundai or any other company listed herein. All information on this site is the opinion of its members and not the opinion of the site itself. ©2016 Madison Ross Media Group. All rights reserved.
Need products for your Hyundai Genesis? Check out your options at the links below:
