Become a registered member for a cleaner interface and faster page loading! It's free!
hyundai genesis sedan   hyundai genesis sedan
DIRECT LINKS: Genesis Motors | Genesis Sedan | Genesis Coupe | Dealer Reviews | Invite a friend!
Go Back   Genesis Motors Forum > Hyundai Genesis Sedan Forums - 3.8 V6, 4.6 V8, 5.0 R-Spec V8 > General 2009-2014 Hyundai Genesis Sedan Discussion
Hyundai Genesis Forum / Magazine Advertise Help us help you! Calendar Today's Posts
Notices
General 2009-2014 Hyundai Genesis Sedan Discussion Forum for discussions regarding the Hyundai Genesis Sedan that don't fit specifically anywhere else.
Hyundai Genesis Forum: Clicking sound when accelerating - 2010- 4.6 tech pkg.
Reply
Thread Tools
  #1
Old 12-24-2010, 02:16 AM
Dano4.6 Dano4.6 is offline
Drives a Hyundai 4.6 V8 Tau Sedan
View Dano4.6's Photo Album
Dano4.6 is on a distinguished road
Default Clicking sound when accelerating - 2010- 4.6 tech pkg.
Remove this ad
I always hear short clicking sound (from transmission and or drive shaft) when accelerating (not flooring it) from a stop on level ground, and its more pronounced and longer duration when accelerating up hill/incline. only happens for a second or two but can always hear it clicking. seems to be associated with 1st gear as its never heard in any other gear or while decelerating... Has anyone experienced the same, if so what did you do to get if fixed?
  #2
Old 12-24-2010, 02:40 AM
homeofstone homeofstone is online now
Drives a Hyundai Genesis 4.6 V8 Tau Sedan
View homeofstone's Photo Album
homeofstone is on a distinguished road
Default Re: Clicking sound when accelerating - 2010- 4.6 tech pkg.
Could be an fuel injector.
__________________
Current vehicles:
2011 4.6 with tech, Athens, GA owner
2011 Mercedes E63 AMG
2005 Mercedes E500 w/sport pkg.
2013 GMC Yukon XL Denali AWD
1965 Ford Mustang 289cid V8 restored
  #3
Old 12-24-2010, 06:54 AM
juryduty juryduty is offline
View juryduty's Photo Album
juryduty is on a distinguished road
Yep I also have a 2010 4.6 and know the problem you are describing. It is usually on hard acceleration and seems to come from the center of the car. I have not taken in mine to the dealer yet, but I believe it is related to the drive shaft (from reading other posts here). Do you have a consistent way to reproduce it? I have been delaying taking it in because I want to wait until I have a reliable way I can show the mechanic.
  #4
Old 12-24-2010, 10:03 AM
Hey Juryduty - Yes under moderate acceleration I can always hear it and it sounds like its right under the center console armrest. if I slowly accelerate and let it shift into 2nd I never hear it. I've taken it to the dealer back in October and they say they can't reproduce problem. Service Manager said they checked the drivel line and re-torqued all the bolts to specification. I've made another appointment for Monday and will be sure to take them on a test drive as its easily reproducible.
  #5
Old 12-27-2010, 05:48 AM
Cool, let us know how it goes at the dealer. I read a couple of posts here that said there is a fix that involves adding an additional washer to the drive shaft so it is straighter.
  #6
Old 01-08-2011, 12:49 AM
After 8 days in the service dept. appears they possibly fixed the problem. Here's what's written up on the service invoice: "customer states vibration and clatter noise coming from in first gear on takeoff. Cause: vibration caused by driveline angle. techline case #4234075 and TSB#10-01-020-1. Ordered parts and started to perform TSB but vehicle already had updated parts" Here are the corrective actions taken per invoice which are different from what the TSB calls for - "removed drive driveshaft from another vehicle and installed in cust's w/shims, tried 2 shims and vibration was worse, removed heat shield- vibration still there, removed shims and rotated center support-vibration worse. tried w/1 shim and center support upside-down still hits shield. rotated center support to original position without shims centered supp bolts holes and hand torqued bolts - test drove and vibration was gone. installed drive shaft back into new veh. - drove customer vehicle total 42 miles" I won't be not totally convinced it's truly fixed until I clock several hundred miles on the car.
Here's yet another problem, again with the power tilt steering - I start up the car Monday to drop the car off for the vibration and clatter noise coming from driveshaft/transmission. I quickly noticed the tilt steering is broke again for the 4th time. So in addition to the vibration and clatter noise coming from driveshaft/transmission the steering tilt goes out again. So the fix for this, so I'm told again, is that a new updated module cable was installed.
I bought this car in June and since June 2010 to December 2010, I've had this car in 4 times for tilt steering being broke. 1st time - they reset tilt module (4days). 2nd time - they replaced module cable with an updated version (5 days). 3rd time - they replaced steering column and module cable (5 days). 4th time - they replaced module cable with yet another updated version (8 days). Nevertheless, at this time I have little confidence the tilt steering is truly corrected/fixed. Aware of the Georgia's lemon law (three repair attempts for the same defect) I have registered this same repeat problem with GA consumer affairs office. I also contacted Hyundai USA consumer affairs and case #4233959 was raised. I was told that Hyundai regional division office would be contacting me in 5 business days. Well its now 7 business days and I've yet to hear from Hyundai's regional division office. The next step for me is to submit a "final repair opportunity notice" to Hyundai.
Here's a summary of my 2010 Genesis 4.6 fault history; in less than 6 months: 4x failures with tilt steering, 1x driver seat sever noise when adjusting backwards- replaced seat rail, 2x reported problem with driveshaft/transmission noise - 1st time service department could not replicate reported problem. 2nd time a different corrective action than what is called for in TSB# TSB#10-01-020-1 was applied since my car already had the updated parts as called for in TSB.
Whoa!!! This is my 2nd Hyundai car. No problems what so ever with my 2006 Azera (46K miles), but wanted a SUV so I traded it for 2007 4runner which has been flawless. Then in 2010 I traded my wife's 2007 (problem free) Acura RDX for the 2010 Genesis. I'm still holding out hope I haven't been burned in my decision in getting a Genesis.... ???
I'll keep you posted.
  #7
Old 01-10-2011, 01:43 AM
Thanks for the update on this! Based on what you've described it's almost not worth dealing with. The clicking sound (at least on my vehicle) is very intermittent and only occurs during hard acceleration and seems to be a little worse when it's cold. I live in California so that's not very often. I too have the seat-rail clicking problem but have not yet brought it in.
Do keep us posted whether this fixed the vibration problem!
  #8
Old 01-12-2011, 02:49 PM
The Doc The Doc is offline
View The Doc's Photo Album
The Doc is on a distinguished road
Same thing - clicking sound for about one to two seconds. When it does happen it seems to come from directly under the console. Sometimes can feel it/sometimes not. Each time has been at 10 - 15 mph. I was out of town for a week not driving the car and for the first 3 days back I heard nothing. Dealer could find nothing wrong to cause this.
  #9
Old 02-02-2011, 10:39 PM
Back in the shop today for an unrelated minor problem (check engine light at 15K which required a computer update) and mentioned this again. They are replacing propeller shaft assembly tomorrow. I'll post whether it solves the problem.
  #10
Old 02-03-2011, 01:11 PM
Rey Rey is offline
Drives a Hyundai Genesis 3.8 V6 Sedan
View Rey's Photo Album
Rey is on a distinguished road
The sound may be from the exhaust pipes hitting the chassis. Under hard acceleration the motor wants to twist on its motor mounts. This twisting action is suppressed by the motor mounts, but the motor mounts are somewhat soft to absorb vibration so some twisting is imparted to the exhaust system.
Production vehicles vary a bit. A friend manufactures headers for GM cars. Typically, he finds his headers do not fit some customer cars just due to production variances. This could mean that exhaust clearances on some Genesis are too tight. If the exhaust is hitting the chassis there may be tell-tale marks on the exhaust/chassis. The fix can be very simple - just a few shims.
Reply
Bookmarks
Download the Cars Connected app
Tags
2010, 46, accelerating, clicking, pkg, sound, tech
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Hyundai Genesis Ads
Remove this column
My Pledge
buy a genesis winged badge emblem
cars connected social network cars connected social networking app for ios cars connected social networking app for android
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2016, vBulletin Solutions, Inc.
GenesisOwners.com recognizes that "Hyundai", "Genesis" and "Genesis Motors", it's logos and various model names and numbers are registered trademarks of the Hyundai Motors Corporation. These terms are used for identification purposes only. GenesisOwners.com is not affiliated in any way with the Hyundai Motors Corporation, Hyundai or any other company listed herein. All information on this site is the opinion of its members and not the opinion of the site itself. 2015 Madison Ross Media Group. All rights reserved.
Need products for your Hyundai Genesis? Check out your options at the links below:
