Registered members do not see this advertisement! Remove it by signing up for free.
hyundai genesis sedan   hyundai genesis sedan
andy's auto sport
Go Back   Hyundai Genesis Forum > Hyundai Genesis Sedan Forums - 3.8 V6, 4.6 V8, 5.0 R-Spec V8 > Wheels, Tires, Detailing and Appearance Modifications
Hyundai Genesis Forum Advertise Help us help you! Calendar Today's Posts
Wheels, Tires, Detailing and Appearance Modifications Discussions regarding wheels, tires, detailing and interior/exterior modifications.
Hyundai Genesis Forum: Removing Shifter Knob?
Reply
Thread Tools
  #1
Old 06-21-2010, 06:57 PM
TEF TEF is offline
Member
Drives a Hyundai 3.8 V6 Sedan
View TEF's Photo Album
TEF is on a distinguished road
Default Removing Shifter Knob?
Remove this ad
I would like to route a sirius antenna cable into the storage area of the center console, but have not been able to remove the shifter knob (an consequently the console itself). Per Hyundai's technical site, it appears that the knob is just pressed onto the shifter lever, but if so, it's really stuck onto the shaft. Has anyone attempted this? If so, how did one remove the knob without damage? So far, all other parts have been removed without problem starting with the rear parcel shelf and moving forward. To Hyundai's credit, all the trim fits well and easy to remove and replace. The car seems very well designed and constructed.
  #2
Old 06-22-2010, 10:41 AM
nearwater's Avatar
nearwater nearwater is offline
Senior Member
Drives a Hyundai 4.6 V8 Tau Sedan
View nearwater's Photo Album
nearwater is on a distinguished road
Default Re: Removing Shifter Knob?
Quote:
I saw the diagram, and also thought it's just pressed in.
Tried pulling it out just for shiz and giggles... didn't budge.
Not sure what else is holding it in place.
I agree. Removed the door panels, seats, and trunk liners, etc. Very well built car indeed.
Dan
__________________
'09 Platinum/Cashmere V8, tech (5/20/'09 build)
  #3
Old 06-22-2010, 09:22 PM
Solano Solano is offline
Junior Member
View Solano's Photo Album
Solano is on a distinguished road
Genesis 3.8 shifter knob can be removed by pulling it (knob) straight up. It's going to be a little hard and it will feel like you are going to break something while pulling it out. But it will come out, there are no screws to remove or locks to undo. It will easily pop back on. I pulled mine out when I had to route wires thru the console.
  #4
Old 06-23-2010, 10:42 AM
TEF TEF is offline
Member
Many thanks to Nearwater and Solano. You confirmed that shift knob was a friction fit to lever and, boy, what a fit. Tried pulling with hands, but due awkward position, made up a simple tool instead. Using a notched 18" length of plywood and second 13" piece I constructed a simple lever device. I placed 13" piece virtically on passenger side of console to serve as a fulcrum. I hooked the base of knob in notch of 18" piece and placed one end on top of fulcrum. Then one just pulls up on the other end and knobs comes off, but it stills requires a lot of force. However, there is no damage to console or one's lower back.
  #5
Old 06-23-2010, 06:04 PM
nearwater's Avatar
Senior Member
That's ingenious!
I'll use your method if I ever need to remove that little son of a gun.
Dan
__________________
Reply
Bookmarks
Tags
knob, removing, shifter
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Hyundai Genesis Ads
Remove this column
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
GenesisOwners.com recognizes that "Hyundai", it's logos and various model names and numbers are registered trademarks of the Hyundai Motors Corporation. These terms are used for identification purposes only. GenesisOwners.com is not affiliated in any way with the Hyundai Motors Corporation, Hyundai or any other company listed herein. All information on this site is the opinion of its members and not the opinion of the site itself. ©2012 Madison Ross Media Group. All rights reserved.
Need products for your Hyundai Genesis? Check out your options at the links below:
Genesis Body Kits at Andy's | Genesis Parts | Genesis Exhaust
