Become a registered member for a cleaner interface and faster page loading! It's free!
hyundai genesis sedan   hyundai genesis sedan
DIRECT LINKS: Genesis Motors | Genesis Sedan | Genesis Coupe | Dealer Reviews | Invite a friend!
Go Back   Genesis Motors Forum > Hyundai Genesis Sedan Forums - 3.8 V6, 4.6 V8, 5.0 R-Spec V8 > General 2009-2014 Hyundai Genesis Sedan Discussion
Hyundai Genesis Forum / Magazine Advertise Help us help you! Calendar Today's Posts
Notices
General 2009-2014 Hyundai Genesis Sedan Discussion Forum for discussions regarding the Hyundai Genesis Sedan that don't fit specifically anywhere else.
Hyundai Genesis Forum: V8 oil filter confusion
Reply
Thread Tools
  #1
Old 11-18-2009, 05:22 PM
TJPark01's Avatar
TJPark01 TJPark01 is offline
Drives a Hyundai 4.6 V8 Tau Sedan
View TJPark01's Photo Album
TJPark01 is on a distinguished road
Default V8 oil filter confusion
Remove this ad
Went to get an oil filter for V8 Genesis for my second oil change. The part number and pieces are different from the first time I did this.
Part number 26320-3C30A
Filter Mahle: 26330-3C300
The parts clerk said the filter part number has changed, can anyone confirm this?
Click image for larger version
ID:	767   Click image for larger version
__________________
4.6 Platinum Metallic/Black
  #2
Old 11-18-2009, 07:28 PM
ctrcbob ctrcbob is offline
Drives a Hyundai Genesis 4.6 V8 Tau Sedan
View ctrcbob's Photo Album
ctrcbob is on a distinguished road
Default Re: V8 oil filter confusion
OK, checked the filter I carry with me.
1. The box says 26320-3F100 (probably updated with your part number)
2. The filter says 26330-3C300 (printed in very light yellow, also Mahle)
Reason I carry a filter with me is just in case I have to get the oil changed somewhere not a Hyundai Dealer (or even a very low volume dealer) I have the correct filter with me.
In addition, the box (26320-3F100) says "Made in Korea".
The filter itself ((26330-3C300) says "Made in Austria" (very hard to read yellow print on white filter)
__________________
Bob CTRC
USN Ret.
Mount Dora, FL (It Could Be Worse)
Penfield, NY (A Quiet Rochester Suburb)
Roswell, NM (Alien Central)
09 Genesis 4.6 Tech (Sold)
10 SHO Ecoboost Twin Turbo
11 MKZ
  #3
Old 11-18-2009, 07:58 PM
Mark_888 Mark_888 is offline
Drives a Hyundai 1G Genesis 3.8 V6 Sedan
View Mark_888's Photo Album
Mark_888 will become famous soon enough
Not that it matters, but V6 and V8 use same filter.
  #4
Old 11-18-2009, 08:00 PM
TJPark01's Avatar
I called another dealer. He confirmed the part number for the
2009 Genesis Sedan V8: 26320-3F100
I told him that another dealer gave me Part number 26320-3C30A. He said it's the same thing, just different part number for different years. The part number on the paper filter element is in fact Mahle: 26330-3C300.
The confusion was also with all these gaskets. Originally the V8 I changed about 6 months ago had 2 gaskets. 1 for the oil filter housing and another for the oil filter housing drain plug. There seems to be 2 extra gaskets, and I get the sneaking suspicion that they are using the same filter for both v8 and v6. I was told the metal gasket is for the oil pan drain plug, but if you remove the plug on the V8, there is no gasket.
__________________
  #5
Old 11-18-2009, 09:28 PM
mrgenesis2009 mrgenesis2009 is offline
Drives a Hyundai 3.8 V6 Sedan
View mrgenesis2009's Photo Album
mrgenesis2009 is on a distinguished road
I'm looking at the invoice for the filters I ordered for my 2009 3.8 and it is different.
26320-3C250 Service kit.
I found this on the web:
26320-3C100 (cartridge)
Azera 2006 and up 3.3L/3.8L engines
Entourage 2007-2009 built before 8/7/08
Sonata 2006 and up 3.3L engine only
Santa Fe 2007 and up 3.3L engine only
Veracruz 2007 built before 5/28/07
26320-3C250 (cartridge)
Entourage 2008 and up built after 8/7/08
Genesis 2009 and up 3.8L engine only
Veracruz 2007 and up built after 5/28/07
26320-3C700 (cartridge)
Genesis Coupe 2010 and up 3.8L engine
26320-3F100 (cartridge)
Genesis 2009 and up 4.6L engine only
Ben
  #6
Old 11-20-2009, 10:52 PM
ASHDUMP ASHDUMP is offline
Drives a Hyundai Equus Signature
View ASHDUMP's Photo Album
ASHDUMP is on a distinguished road
Found this on the www.hmaservice.com
Quote:
The engine oil filter has been superseded from part number 26300-35500 to part number 26300-35501. This oil filter is currently used on all Hyundai models.
The change is cosmetic, to include the words Kia Motors, the Kia logo and the new part number. Form, fit and function have not been affected.
To insure proper filtration of the lubrication system, only Hyundai Genuine Parts should be installed by a Hyundai approved facility. Damage resulting from parts other than Hyundai Genuine Parts may not be covered under warranty.
Looks to be the only change is that they put KIA Motors and its logo on the filter.
  #7
Old 11-20-2009, 11:09 PM
Where do you guys buy your oil filters? Do you buy them to bring with you to shops that might not carry the correct size? Or are you all changing your own oil?
  #8
Old 11-21-2009, 11:49 AM
TJPark01's Avatar
Quote:
I change it myself in the garage. Cheaper and I know it is being done correctly. The biggest error would be to overfill, second is probably improper weight. To fully drain the oil, it takes nearly an hour, and most places wont let the car sit on a lift for that long.
__________________
  #9
Old 11-23-2009, 09:21 AM
I also change my own oil and I bought several filters from a dealership online. I think they were 5 or 6 dollars each. I keep myself stocked up so I don't have to go out and buy this stuff when I need it. They other reason is to make sure it is done right. It really is easy to do, you just have to have the right tools.
Ben
  #10
Old 11-23-2009, 03:08 PM
gerryb's Avatar
gerryb gerryb is offline
View gerryb's Photo Album
gerryb is on a distinguished road
Changed my oil yesterday. Second change - 7400 miles. First one was a dealer comp. Took about 30 minutes. I let the oil drain for about 25 minutes. 27MM socket/ratchet, 10mm socket/2" socket extension/ratchet, phillips screwdriver and a size 6 hex/allen wrench are all that is required as far as tools. I used the 'signature series' Amsoil and a standard Hyundai MANN oil filter. DO NOT TRY using a adjustable on the 27mm oil filter cover-odds are you'll strip the plastic as it is on there nice and tight. I used a 1" socket with 18" ratchet and still had to apply a little pressure. I have a lift in my garage and so access to everything is easy. Getting the shroud off may take some time if you are on a creeper but still easy to do.
__________________
2009 Genesis 4.6 Black/Black with Tech Pkg
2000 BMW 528i
2004 Ford F150 XLT
Reply
Bookmarks
Download the Cars Connected app
Tags
confusion, filter, oil, v8
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Hyundai Genesis Ads
Remove this column
My Pledge
buy a genesis winged badge emblem
cars connected social network cars connected social networking app for ios cars connected social networking app for android
Powered by vBulletin® Version 3.8.9
Copyright ©2000 - 2016, vBulletin Solutions, Inc.
GenesisOwners.com recognizes that "Hyundai", "Genesis" and "Genesis Motors", it's logos and various model names and numbers are registered trademarks of the Hyundai Motors Corporation. These terms are used for identification purposes only. GenesisOwners.com is not affiliated in any way with the Hyundai Motors Corporation, Hyundai or any other company listed herein. All information on this site is the opinion of its members and not the opinion of the site itself. 2015 Madison Ross Media Group. All rights reserved.
Need products for your Hyundai Genesis? Check out your options at the links below:
