Become a registered member for a cleaner interface and faster page loading! It's free!
hyundai genesis sedan   hyundai genesis sedan
DIRECT LINKS: Genesis Motors | Genesis G80 | Genesis G90 | Genesis Sedan | Genesis Coupe | Equus | Invite a friend!
Go Back   Genesis Motors Forum > Hyundai Genesis Sedan Forums - 3.8 V6, 4.6 V8, 5.0 R-Spec V8 > Hyundai Genesis Sedan Performance Parts and Modifications
Hyundai Genesis Forum / Magazine Advertise Help us help you! Calendar Today's Posts
Notices
Hyundai Genesis Sedan Performance Parts and Modifications Discussions regarding high performance modifications for the drivetrain of the Hyundai Genesis Sedan.
Hyundai Genesis Forum: Genesis Performance Chip
Reply
Thread Tools
  #1
Old 11-03-2009, 11:10 PM
PAS123 PAS123 is offline
Drives a Hyundai Genesis 3.8 V6 Sedan
View PAS123's Photo Album
PAS123 is on a distinguished road
Default Genesis Performance Chip
Remove this ad
I just came across an ebay merchant offering a performance chip for the 2009/2010 Genesis Sedan. It does not specify if it is for the the 3.8 or 4.6 engine.
I plan on contacting this merchant and see what engine it is meant to be installed in. I'll post back with the reply.
These are the benefits they are claiming:
Up to 15 MPG - improved fuel efficiency
50+ horsepower
50+ FT/LB of torque
Improved acceleration
Smoother throttle response through RPMs
Improved top end power
Smoother shifting
Better low end torque
Improved towing capacity
Smoother power throughout the powerband
Extends the life of engine spark plugs
Extends the life of engine oil
Extends the life of engine belts
Improved engine performance extends the time between costly engine tune-ups and check-ups.
Has anybody tried this particular one? Here is the link: http://cgi.ebay.ca/2in1-PERFORMANCE-...item20ade37685
__________________
2015 Genesis Sedan 3.8 with Tech Package HTRAC Santiago Silver
  #2
Old 11-03-2009, 11:18 PM
dataguy's Avatar
dataguy dataguy is offline
View dataguy's Photo Album
dataguy will become famous soon enough
Default Re: Genesis Performance Chip
It's not a chip, it's a diode (as you can see by the negative feedback). The way they usually work is to fool the air intake sensor so that the ECU thinks the fuel mix needs to be richer than it normally would be. Net result is a few more HP with worse emissions.
As for the MPG claims, if manufacturers could do anything to make higher MPG *and* more HP at the same time without exceeding emissions targets for a few bucks, I'm pretty sure they would do it. That's because as soon as one company did it, every company would. Unless you subscribe to the conspiracy theory about the government, auto companies, and the oil industry. And even then, every company and government in the world would need to be in on it.
So unless you want to risk voiding your warranty for the unlikely possibility of a miracle performance boost, I'd say steer clear.
__________________
2009 Genesis Sedan 3.8 (Tech)
Titanium Grey/Black (Rebadged)
<-- Track your Genesis MPG at Fuelly
Best MPG: 29.0, Worst MPG: 18.8
  #3
Old 11-04-2009, 01:20 AM
Thanks for the response Dataguy. I checked out the sellers feedback and found that he is not selling a performance chip as he claims in the the ad. There are a few people that he suckered into buying the gizmo he is selling that are really disappointed with it. Others plain warn you that it is a scam.
As you suggest, I'll be staying real clear of this one. Thanks Again
The point that sparked my interest was the increased fuel economy.. I guess my next mod will be a K & N filter.
__________________
  #4
Old 11-04-2009, 06:10 PM
imitiday imitiday is offline
Drives a Hyundai 4.6 V8 Tau Sedan
View imitiday's Photo Album
imitiday is on a distinguished road
My service manager says no to the k/n filter,some cars have had a problem
with the oil soaked filter.So I nixed it!
  #5
Old 11-04-2009, 07:38 PM
TJPark01's Avatar
TJPark01 TJPark01 is offline
View TJPark01's Photo Album
TJPark01 is on a distinguished road
Simply swapping to a K&N air filter is going to make little to no difference in the performace of your car. You would only feel it if the filter was totally clogged, otherwise the computer is totally controlling air flow. To make a meaningful change you would have to change the whole intake housing and filter, change the settings on the computer through the OBDII then add a cat back exhaust system to reduce back pressue. Even change the headers if you're so inclined. My point is....an engine is simply an air pump, you have to open up both intake and exhaust if you want more performance.
__________________
4.6 Platinum Metallic/Black
  #6
Old 11-04-2009, 07:53 PM
wallymn wallymn is offline
View wallymn's Photo Album
wallymn is on a distinguished road
Until someone can defeat the ECS, you can't enjoy any of that power. the nanny already hits the brakes in 1/2 gear under full throttle. and you are gov'd at the top end, So the perf mods, if they work. might give you some passing speed in 3rd gear.....
__________________
2009 Genesis 4.6 w/Tech
Black/Black
  #7
Old 11-04-2009, 10:27 PM
Nabber's Avatar
Nabber Nabber is offline
View Nabber's Photo Album
Nabber is on a distinguished road
Quote:
Originally Posted by wallymn View Post
Until someone can defeat the ECS, you can't enjoy any of that power...
EXACTLY! The ONE thing I want is the ability to fully disable the ESC (which includes a traction control component). I don't need more power; I need a way to take full advantage of the power I already have.
__________________
Sterling Blue/Black 4.6L V8 w/ Tech Pkg
Mods: Always hot power taps, hardwired Escort 9500ix detector, 18" center caps, rear wing emblem, airbag emblem.
Reply
Bookmarks
Download the Cars Connected app
Tags
chip, genesis, performance
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Hyundai Genesis Ads
Remove this column
My Pledge
buy a genesis winged badge emblem
cars connected social network cars connected social networking app for ios cars connected social networking app for android
Powered by vBulletin® Version 3.8.9
Copyright ©2000 - 2016, vBulletin Solutions, Inc.
GenesisOwners.com recognizes that "Hyundai", "Genesis" and "Genesis Motors", it's logos and various model names and numbers are registered trademarks of the Hyundai Motors Corporation. These terms are used for identification purposes only. GenesisOwners.com is not affiliated in any way with the Hyundai Motors Corporation, Hyundai or any other company listed herein. All information on this site is the opinion of its members and not the opinion of the site itself. 2015 Madison Ross Media Group. All rights reserved.
Need products for your Hyundai Genesis? Check out your options at the links below:
