Become a registered member for a cleaner interface and faster page loading! It's free!
hyundai genesis sedan   hyundai genesis sedan
DIRECT LINKS: Genesis Motors | Genesis Sedan | Genesis Coupe | Dealer Reviews | Invite a friend!
Go Back   Genesis Motors Forum > Hyundai Genesis Sedan Forums - 3.8 V6, 4.6 V8, 5.0 R-Spec V8 > General 2009-2014 Hyundai Genesis Sedan Discussion
Hyundai Genesis Forum / Magazine Advertise Help us help you! Calendar Today's Posts
Notices
General 2009-2014 Hyundai Genesis Sedan Discussion Forum for discussions regarding the Hyundai Genesis Sedan that don't fit specifically anywhere else.
Hyundai Genesis Forum: 3.8l lambda engine specs
Reply
Thread Tools
  #1
Old 08-29-2009, 05:45 AM
wrt018 wrt018 is offline
Drives a Hyundai In His/Her Dreams (Doesn't own one yet)
View wrt018's Photo Album
wrt018 is on a distinguished road
Default 3.8l lambda engine specs
Remove this ad
hi im new to this site just wondering if anyone had any specs (bore, stroke, weight etc.) and if the engines have any faults from standard.
  #2
Old 08-29-2009, 10:43 AM
jwaters943's Avatar
jwaters943 jwaters943 is offline
Drives a Hyundai 3.8 V6 Sedan
View jwaters943's Photo Album
jwaters943 is on a distinguished road
Default Re: 3.8l lambda engine specs
This is all I could find:
DOHC 3.8-Liter Lambda, V6, 24-Valve, DOHC, MPFI Engine; Front/Longitudinal Mounted With Horsepower Of 290@6000, Torque Of 262@3500, Alloy Block and Alloy Cylinder Heads
Compression Ratio 10.40
Horsepower@RPM 290 hp @6000rpm
Torque Lbs. Per Ft 264@ 3500
Cylinder Configuration Vee
Valves per cylinder 4
Bore 3.78
Stroke 3.43
Engine Block Material Alloy
Block Head Material Alloy
Fuel Capacity 19.30 gallons
Fuel Type Unleaded
Fuel Delivery Name MPFI
__________________
'09 Hyundai Genesis 3.8
Current Mods:
35% Metallic Tint, KDM Wing Emblems (Front/Rear/Wheel Center Caps/Steering Wheel), Chrome Exterior Door Strips, LED Illuminated Door Sills,
Accessory Cargo Mat, Trunk Speaker Cover, Color-Matched Mud Guards, Spec-1 Design Lip Spoiler
  #3
Old 08-29-2009, 09:54 PM
thanks for that. do you know the overall dimentions of the engine??
  #4
Old 08-29-2009, 10:20 PM
Mark_888 Mark_888 is offline
Drives a Hyundai 1G Genesis 3.8 V6 Sedan
View Mark_888's Photo Album
Mark_888 will become famous soon enough
Quote:
I have a couple of questions:
1. Do you want specs for the Genesis Sedan V6 or Genesis Coupe V6 (they have slightly different specs, although dimensions may be the same unless you count headers, etc).
2. Why are you wanting to know the overall dimensions (just curious)?
3. What does "and if the engines have any faults from standard" mean?
  #5
Old 08-31-2009, 02:43 AM
well im not sure weather i want the sedan or coupe so if you know both that would be great.
me and my dad have been racing speedway for a while and we were thinking of making a hyundai excel and we are only allowed to go 6 cylinder and we had to keep with the hyundai brand.
for the faults i was just wondering if there is anything that goes wrong with them from standard like they have overheating problems or something like that that you know of??
  #6
Old 08-31-2009, 12:58 PM
The V6 coupe and sedan 3.8 V6 engines are slightly different, but I don't recall what all the differences are. The coupe has a little more HP. They have different transmissions (Sedan has the Aisin and Coupe has the ZF).
The sedan version (not sure about coupe) has a top mounted oil filter (cartridge refill) which seems to drain back into the crankcase when the engine stops, causing somewhat noisy startups. Beyond that, I don't know of any problems and so far I am very satisfied with the Genesis V6 drive-train.
  #7
Old 09-01-2009, 05:58 AM
thanks for that,
do you know what gearbox is better and how many gears the both of them have??
  #8
Old 09-01-2009, 11:35 AM
thanks for that,
They both have 6 gears. The ZF is also used by BMW and some other German cars and is a little more robust and more appropriate for the V8 and V6 Coupe, but I would not necessarily say it is better than the Aisin (Aisin makes transmissions for a lot of cars, including some Lexus--they are 50% owned by Toyota).
If you got to Hyundai website I think you can find the gear ratios.
  #9
Old 09-01-2009, 12:43 PM
TJPark01's Avatar
TJPark01 TJPark01 is offline
Drives a Hyundai 4.6 V8 Tau Sedan
View TJPark01's Photo Album
TJPark01 is on a distinguished road
thanks for that,
http://cid-5103094dcbb8400e.skydrive...n%20Sheets.pdf
__________________
4.6 Platinum Metallic/Black
  #10
Old 02-02-2010, 02:18 AM
hi again. we have done some research and we think that the kia grand carnival has the same engine. i was just wondering if anyone knew this for sure? also i was wondering if the manual bell housing was seperate from the gearbox housing in a rear wheel drive and what car i would find one in??
thanks
Reply
Bookmarks
Download the Cars Connected app
Tags
38l, engine, lambda, specs
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Hyundai Genesis Ads
Remove this column
My Pledge
buy a genesis winged badge emblem
cars connected social network cars connected social networking app for ios cars connected social networking app for android
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2016, vBulletin Solutions, Inc.
GenesisOwners.com recognizes that "Hyundai", "Genesis" and "Genesis Motors", it's logos and various model names and numbers are registered trademarks of the Hyundai Motors Corporation. These terms are used for identification purposes only. GenesisOwners.com is not affiliated in any way with the Hyundai Motors Corporation, Hyundai or any other company listed herein. All information on this site is the opinion of its members and not the opinion of the site itself. 2015 Madison Ross Media Group. All rights reserved.
Need products for your Hyundai Genesis? Check out your options at the links below:
