Scott, which 'relay' are you planning on changing?
Turn Signal Lamp Control
The Turn Signal Lamp Control function controls turn signal lamps and indicators.
1.FAM : Normal Operating Condition
While IGN Switch FAM is IGN state, if Turn Signal RH Switch or Turn Signal LH Switch or Hazard switch is ON then turn signal outputs are turned ON following the switch input (LEFT, RIGHT or HAZARD).
2.FAM : Double Blinking Condition
In case of activation of hazard the fault detection will be able to detect the failure only if 3 bulbs are broken-down.
The double blinking works at IGN Switch FAM is IGN state, double blinking for Hazard.
In case of turn signal activation when one of the FRONT or REAR is broken-down (Lamp failure), the turn signal blinks with double frequency.
3.FAM : SCG (SHORT CIRCUIT TO GND) Fault Condition
If The FAM detects Short circuit to Ground, then FAM turns off the OUTPUT
.The fault detection is carried out continuously, until fault is confirmed by FAM. Once FAM confirms SCG, FAM keeps the fault condition until
flasher trigger condition is changed.
