18" Wheel Caps
^ Don't you just have yo heat up the center cap and pull it off with some tape?
Yup, heat it up, the cap H cap pulls off and the tape on that cap can be transfered to the wing cap, or you can use the 3M double sided tape in your toolbox.
Yeah, there are a few ways to get there. I enjoyed the instant snap-on approach. Thanks, though.
Why are you stalking my toolbox?!?!?!?! lol :D
I'm with you there; I bought the caps and the wings as a package and put the original center caps in the bags for the new ones. Hopefully the next owner will appreciate my efforts. ;)
I'd like to just buy the center piece(s) for the wheel caps, but I haven't been able to find them for the 2012 3.8L (w/tech) 18" wheels. scottdk, would the $28 caps you mentioned be a match? (I visited the SFR site and those are indicated for 17" wheels. And the photo of that wheel is altogether different).
mark
mark
The caps will fit the 17", 18", and 19" Genesis wheel since the center is the same size on all the Genesis wheels.
I had them on my 18" V8 wheels, and when I bought the R Spec wheels (19") I transferred the winged cap centers to my R Spec wheels.
mark
I think this is what you may need http://www.ebay.com/itm/18inch-WING-CENTER-WHEEL-CAP-SET-GENESIS-V8-4-6-SEDAN-2008-2012-/260989119389?fits=Model:Genesis&hash=item3cc429eb9d&item=260989119389&pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr
Just ordered a set for my 2011 Genesis 4.6 -- next to get some wings. Thanks for all the tips included in these threads.
I installed the wing caps on my 18" wheels some time back. They are OEM direct from Korea. My original H caps weren't the easiest things to remove when I rotated my tires but the replacement wing caps are darn near impossible. Every time I remove one I expect it to break in half. I can't understand why they fit so snug. They are even difficult to reinstall. Has anyone else had this problem or is there a trick I should know? Any help would be appreciated. (yes, I know the slot is to be aligned with the valve stem)
Would these fit 2013 r-spec wheel caps?
eBay doesn't recornize 2013 r-spec parts and accesorries so not sure where to get them.
Anyone?
Anyone?
R spec sedan uses same center cap as 17" 2009 - 2012 wheels
I know this is an old posting, but thanks to those that did. I was about to spend about $80 to replace the whole center piece.
Re: 18" Wheel Caps - tutorial, no pix
i just got the SFR caps and replaced the flying H today. couple of notes for those who have yet to do/try this ...
you pretty much have to drill a hole in the back side of both SFR cap and flying H wheel cover to get the existing stuff off.
the existing flying H caps have almost NO clearance between the wheel cover plastic and the logo. if you are aggressive or use a very sharp bit, you'll perforate the H. i used a low drill rotation speed and started with a 1/8" bit for a pilot hole, then used a 3/8" metal bit with a very flat point to get thru the plastic. the last few drill rotations were done by hand to avoid puncture/distortion of the flying H.
for the SFR caps, there's around 1/8" between the back of the cap and the plastic, so you can be a little less precise ... but it's the same deal: do the last few rotations by hand to protect yourself.
the flying H caps should come off fairly easily after 60 seconds of heat from a hair dryer on high setting. apply heat directly to the flying H. as stated elsewhere, turn the whole unit upside down and use the eraser end of a sacrificial pencil to push thru. the cover acts as a "holder". the tape for these is a donut (hole in middle) and can be preserved & reused if you're careful.
the SFR winged caps are another story - the wing caps are really stuck on the plastic. i removed the protective plastic film before putting heat directly to the wing surface. i used 3 minutes of high heat and it was still a bear to remove. i used the wood end of the sacrificial pencil to push thru the drill hole, but i rounded off the corners of the pencil beforehand to keep from denting the surface of the wing from the rear while pushing thru.
to help direct the heat, i put each cap in a stoneware cereal bowl and blew heat straight down. this kept the cap from flying around due to air flow and focused the heat. i used some small pliers to grip the cap once heated; it was too hot to hold.
i used the pliers to grab tabs on the plastic back and used a thin screwdriver to slide along the outer edge until locating a gap. i then grabbed the tab at that gap, put the opposite cap edge on a counter and held the cap at an angle with the pliers while pushing the pencil thru the drill hole. the wing didn't come off all at once - i had to break one side free, and it took significant effort to get it to release.
to apply the released wing caps to the wheel cover, i heated (separately) both metal wing cap and the sticky tape preserved on the cover, then gave 'em a good squeeze together for around a minute (gloves!) until i was sure it held.
i then filled the wheel cover drill holes on the back with a dollop of RTV.
hope someone finds this useful.
