Become a registered member for a cleaner interface and faster page loading! It's free!
hyundai genesis sedan   hyundai genesis sedan
DIRECT LINKS: Genesis Motors | Genesis G70 | Genesis G80 | Genesis G90 | Genesis Sedan | Genesis Coupe | Equus
Go Back   Genesis Motors Forum > Hyundai Genesis Sedan Forums - 3.8 V6, 4.6 V8, 5.0 R-Spec V8 > General 2009-2014 Hyundai Genesis Sedan Discussion
Hyundai Genesis Forum / Magazine Advertise Help us help you! Calendar Today's Posts
Notices
General 2009-2014 Hyundai Genesis Sedan Discussion Forum for discussions regarding the Hyundai Genesis Sedan that don't fit specifically anywhere else.
Hyundai Genesis Forum: Running Out of Gas
Reply
Thread Tools
  #1
Old 08-10-2012, 01:00 PM
Kirkwood Kirkwood is offline
Drives a Genesis 3.8 V6 Sedan
View Kirkwood's Photo Album
Kirkwood is on a distinguished road
Thumbs down Running Out of Gas
Members don't see this ad
I ran out of gas the other day in my Genesis sedan when the computer said I had 48 miles to go, the low fuel light was not on and the gas gauge said that I had 1/16 of a tank left. I have previously gone below 30 miles fuel left and not run out of gas, so something changed. Anyone have any idea?
  #2
Old 08-10-2012, 06:55 PM
maxmar04 maxmar04 is offline
Drives a 3.8 V6 Sedan
View maxmar04's Photo Album
maxmar04 is on a distinguished road
Default Re: Running Out of Gas
Hmm, very strange. It could be a couple of things of things I can think of:
Clogged or Busted gas line?
Dirty or faulty fuel sensor?
It couldve been a computer glitch (very possible since it is a very new car making the above scenarios highly unlikely)
There are actually many many things that could have caused this.... Too many for me to list right now
I have gone about 10 miles past the almost empty warning "-- miles left" (comes up after "30 miles left") without running out of gas.
Do not crank the car until you add more gas and rock the car side to side a bit, then head to the dealership and see what they have to say about it.
__________________
'10 black 3.8 sedan
rebadged with black wings
debadged "genesis"
completely redone sound system
insulation throughout entire car
20" lexani lx-20
painted brake calipers
15% tint and 50% windshield
lowbeam/fog HIDs (as well as independent fog mod)
blacked out tail lights and mirror side markers
ChromeIntakes CAI
COMPLETE blue LED conversion everywhere (including A/C vents)
White license plate LED's
Underbody LED's
soon to come > paint grill,murder (paint all chrome pieces black)
  #3
Old 08-11-2012, 04:56 AM
mikec mikec is offline
Drives a Genesis 4.6 V8 Tau Sedan
View mikec's Photo Album
mikec is on a distinguished road
Did the engine really run out of gas or could it have died for some other reason? One out-of-gas possibility is a defective fuel pick-up pipe. A small leak near the bottom of it would make it suck air instead of gas when the gas level is lower than the leak. A dent in the fuel tank that snags the fuel level sensor float, an incorrectly installed sensor/float, and bad sensor/float will make the fuel gauge read incorrectly high.
The Genesis sedan monitors fuel tank level and compares that to what the engine computer thinks it's burned. If the "I've burned this much gas" doesn't compare to "tank says this much gas has been used" then diagnostic code P0461 is set. The tolerance is 11 liters or 2.6 gallons - i.e. if the tank fuel level is more than 2.6 gallons different from what the computer thinks it's burned you'll get the error code. This is used to monitor the fuel system for gross fuel leaks and issues with the evaporative emissions canister (the charcoal canister).
mike c.
  #4
Old 08-11-2012, 08:35 AM
genesis20 genesis20 is offline
View genesis20's Photo Album
genesis20 is on a distinguished road
Not a good idea to let your tank get past the 1/8 empty level. Running out of gas is not good for the injectors because they need gas for lubrication. At least that used to be the case in older vehicles. Newer engines might be different but I think they still need to be lubricated by gasoline. Please correct me if I am wrong.
  #5
Old 08-11-2012, 09:25 AM
Shawn33 Shawn33 is offline
View Shawn33's Photo Album
Shawn33 is on a distinguished road
Along with this the fuel pump is typically submerged in gasline which helps cool it. Running it to empty allows the pump to heat up considerably. Keeping the fuel level above 1/8th will help prolong the life of the fuel pump as well.
Shawn
__________________
2015 3.8 AWD Ultimate
Ibiza Blue/Ivory Interior
  #6
Old 08-11-2012, 10:06 AM
CanukV6 CanukV6 is offline
View CanukV6's Photo Album
CanukV6 is on a distinguished road
The 'Miles to Empty' display should not be relied on, as I believe it uses past average fuel consumption as an indicator, not real time fuel consumption. Therefore if you have had a period of economical highway driving and then you fill up, the M-T-E reading will be quite high. If you then run around the city on hot days with lots of stop and go driving, the actual fuel consumption will be a lot higher than the previous average. While I assume that the system does adapt to the higher consumption (by revising the average fuel consumption) it will still show a false M-T-E reading.
If you Reset your M-T-E at every fill up this problem will be diminished, but for those that never Reset, the average consumption may be a lot higher than actual.
__________________
1st: 2009 3.8 V6, Cabernet/Cashmere, with Tech Package. Returned at Lease End. 119,750km (74,850 miles).
2nd: 2012 3.8 V6, Twilight Blue Pearl/Cashmere, with Tech Package. Returned at Lease End. 105,000km (65,625 miles).
Current: 2015 3.8 V6 HTRAC Casablanca White/Beige Two-Tone, with Luxury Package.
  #7
Old 08-11-2012, 10:07 AM
EXBMWGUY's Avatar
EXBMWGUY EXBMWGUY is offline
Drives a Genesis 5.0 V8 R-Spec Sedan
View EXBMWGUY's Photo Album
EXBMWGUY is on a distinguished road
Default
Add to this the potential harm to the catalytic converter from running out of gas.
__________________
2012 R-Spec, Black, Tinted, Wings - Rear, Wheels, Steering Wheel.
  #8
Old 08-11-2012, 11:34 AM
Qbedobedoo's Avatar
Qbedobedoo Qbedobedoo is offline
View Qbedobedoo's Photo Album
Qbedobedoo is on a distinguished road
Quote:
Originally Posted by CanukV6 View Post
If you Reset your M-T-E ...
How do you reset the MilesToEmpty?? I thought it was a calculated value..
__________________
2012 3.8 Sedan Titanium Grey Metallic
Front, back and steering wheel emblem..
  #9
Old 08-11-2012, 12:16 PM
Sorry, what I should have said is to Reset the Average Fuel Consumption. In my car you scroll through the trip computer display on the Instrument Cluster until you come to Average Fuel Consumption then hold the button down until it resets. On my 2009 there was a seperate Reset button.
__________________
  #10
Old 08-11-2012, 01:01 PM
swltf183 swltf183 is offline
View swltf183's Photo Album
swltf183 is on a distinguished road
In addition to everything else mentioned, all the debris floating on the top of the gas is sucked into the system. Like a bathtub drain. That last swallow contains all the floaters.
Reply
Bookmarks
Download the Cars Connected app
Tags
gas, running
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Hyundai Genesis Ads
Remove this column
My Pledge
Buy OEM Genesis badges and emblems
cars connected social network cars connected social networking app for ios cars connected social networking app for android
Powered by vBulletin® Version 3.8.9
Copyright ©2000 - 2016, vBulletin Solutions, Inc.
GenesisOwners.com recognizes that "Hyundai", "Genesis" and "Genesis Motors", it's logos and various model names and numbers are registered trademarks of the Hyundai Motors Corporation. These terms are used for identification purposes only. GenesisOwners.com is not affiliated in any way with the Hyundai Motors Corporation, Hyundai or any other company listed herein. All information on this site is the opinion of its members and not the opinion of the site itself. 2016 Madison Ross Media Group. All rights reserved.
Need products for your Hyundai Genesis? Check out your options at the links below:
